Hello, I’m still dragging my way around ZimaOS and learning.
So far I haven’t done anything with my server until I get a proper backup setup which I want to achieve with Kopia which is a somewhat more complete backup solution.
So I have my ZimaOS server (main one) and an old 2 bay Synology for backup. I want to setup a SMB folder on the Synology NAS that will recieve Kopia’s backups. The SMB folder is properly mounted on ZimaOS but now, for the life of me, I cannot make Kopia to find that folder.
What should be the correct syntax / structure of the path for this folder, because I have tried so many different ones and Kopia keeps saying “Connect Error: INTERNAL: internal server error: cannot access storage path: stat smb://name of server/backup folder: no such file or directory”.
I made similar questions to Google Gemini and his reccomendation was to do it this way, by having the SMB folder mounted into ZimaOS but I’m asking myself now if I this could be wrong and it would be better to point Kopia directly at the source folder into the Synology NAS and what would be the correct path structure for that.
Thank you and have a good day.
