Hello, I was following the KL Tech video to set up ZimaOS with all of the ‘arrs’ and I cannot get past the prowlarr setup. When I try to launch the app after the custom install, it times out. Any ideas?
I get the error:
Service Unavailable
The application is not running properly. We recommend checking:
All configuration items (e.g., port, path).
The access permissions of the storage directories.
The connection settings for dependent services like the database.
Please check the detailed startup logs in the “Configuration” menu to identify the specific issue.
And I believe that these are the logs:
prowlarr | GID/UID
prowlarr | ───────────────────────────────────────
prowlarr |
prowlarr | User UID: 1000
prowlarr | User GID: 1001
prowlarr | Linuxserver.io version: 2.3.5.5327-ls147
prowlarr | Build-date: 2026-05-20T07:05:39+00:00
prowlarr |
prowlarr | [custom-init] No custom files found, skipping…
prowlarr | [Info] Bootstrap: Starting Prowlarr - /app/prowlarr/bin/Prowlarr - Version 2.3.5.5327
prowlarr | [Info] AppFolderInfo: Data directory is being overridden to [/config]
prowlarr | [Debug] Bootstrap: Console selected
prowlarr | [Info] MigrationController: *** Migrating data source=/config/prowlarr.db;cache size=-20000;datetimekind=Utc;journal mode=Wal;pooling=True;version=3;busytimeout=1000 ***
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: DatabaseEngineVersionCheck migrating
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: PerformDBOperation
prowlarr | [Info] NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSQLiteProcessor: Performing DB Operation
prowlarr | [Info] DatabaseEngineVersionCheck: SQLite 3.50.4
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 279.6397937s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: DatabaseEngineVersionCheck migrated
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 279.6442653s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: VersionMigration migrating
prowlarr | [Info] NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSQLiteProcessor: Beginning Transaction
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: CreateTable VersionInfo
prowlarr | [Info] NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSQLiteProcessor: CREATE TABLE “VersionInfo” (“Version” INTEGER NOT NULL)
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 0.0286869s
prowlarr | [Info] NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSQLiteProcessor: Committing Transaction
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: VersionMigration migrated
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 275.4973863s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: VersionUniqueMigration migrating
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: CreateIndex VersionInfo (Version)
prowlarr | [Info] NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSQLiteProcessor: CREATE UNIQUE INDEX “UC_Version” ON “VersionInfo” (“Version” ASC)
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 0.0054069s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: AlterTable VersionInfo
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 0.000436s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: CreateColumn VersionInfo AppliedOn DateTime
prowlarr | [Info] NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSQLiteProcessor: ALTER TABLE “VersionInfo” ADD COLUMN “AppliedOn” DATETIME
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 0.0033591s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: VersionUniqueMigration migrated
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 87.0640194s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: VersionDescriptionMigration migrating
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 2.33E-05s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: CreateColumn VersionInfo Description String
prowlarr | [Info] NzbDrone.Core.Datastore.Migration.Framework.NzbDroneSQLiteProcessor: ALTER TABLE “VersionInfo” ADD COLUMN “Description” TEXT
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: => 0.0006523s
prowlarr | [Info] FluentMigrator.Runner.MigrationRunner: VersionDescriptionMigration migrated
