Jellyfin is not working properly. The media library scan is also not working, and new files are not being detected. Please check the issue and provide a solution.
Did you follow the official Jellyfin setup guide here?
https://www.zimaspace.com/docs/zimaos/media-server-setup-with-jellyfin
At the moment there is not enough information here for anyone to check the issue properly.
Jellyfin not detecting new files can be caused by a few different things, for example:
- the media folder path is not mounted correctly into the Jellyfin container
- Jellyfin does not have permission to read the folder
- the files were added to a different storage path than the one Jellyfin is scanning
- the library scan is failing due to an error inside Jellyfin
- the app/container may need to be restarted or recreated with the correct bind path
Please provide some more details so people can help you properly:
docker ps | grep -i jellyfin
docker logs --tail=100 jellyfin
Also please confirm:
- Your ZimaOS version
- Where your media files are stored
- The exact folder path added inside Jellyfin
- Whether Jellyfin can see the old files but not the new files, or nothing at all
Without this information, it is not really possible to give a correct solution.
