The new copy/paste progress status in v1.2.2 (showing how many files is left) is a nice update. But I’m still experiencing some issues.
Dropbox Copying Issues
When I copy from Dropbox, I experience repeated hangs/stops. It simply stops copying. There is no way to resume the copying. I’m not sure why this is happening since it’s a direct connection to Dropbox.
Files Copy/Paste Stuck
On top of the Dropbox issue, the copy/paste progress gets “stuck.” So even if I cancel the Dropbox copy progress, and re-copy the same folders and re-paste them, the old stuck progress shows up, not the new progress.
If I copy a different file and try to paste it, the old progress gets triggered again, not a new progress for a new file.
Refreshing the Files window does not reset the copy/paste status.
Copy/Paste Status Disappears with Window Reload
Even when copying/pasting does work, if I refresh the window, the progress status simply disappears!
If I copy a file, then refresh the window, the paste option disappears!
Why isn’t this status being held server-side, independent from the loaded window?
Missing Online Storage
Along with Dropbox, Google Drive, and OneDrive, wasn’t iCloud also shown in product photos? Will it be coming at a later point?
Hi Timothy,
It seems that you have encountered the bugs of Dropbox Copying Issues and Files Copy/Paste Stuck in Files. We will record and track them through the project management tool.
Regarding your suggestion of storing the copy status on the server-side, we will record it in the product and design improvement items and deal with it after evaluation.
Orca
Hi, I am the product manager of ZimaOS @timothy
Apple doesn’t seem to provide a similar interface that would allow files to appear in other file browsers
If you want to backup your photos, you can use immich app on your iPhone
I’d be happy to tell you how to install immich
If Apple has any changes of mind, ZimaOS will follow suit
I’m talking about Zima Files, not Apple/iOS Files…
Hi Timothy,
I invited ET to answer your question about the missing iCloud online storage feature. The interface he mentioned refers to the open API that iCloud does not directly provide to the public.
We are also working hard to investigate the feasibility of access.
We have recorded the bugs you mentioned about Files copying, and will synchronize them to you as soon as the problem is solved.
Orca
Oh I understand now, thanks.
Hi Timothy,
Thank you again for your valuable suggestions on ZimaOS.
Orca
Hi,@timothy ,We just had a discussion on this issue and the response to the question is as follows:
1.dropbox copy hang problem we will merge it into optimization item to optimize.
2. The file copying progress display abnormality problem, due to the cancellation mechanism problem, need to complete at least one file before the real cancel, resulting in the previous cancellation is not really canceled.
3. For the sake of simple user operation, we only keep the progress of one file operation, but you can actually do more than one operation, but you just can’t see the progress.
4. Paste the state of the problem of loss after refreshing, the state is not submitted to the server so it will be lost, such as the server to save the state of multi-user operations will be confused.
Above is the content of our discussion, look forward to your reply.
Sounds like progress.
However, I’ve been using Mac Finder for all of my transfers, including Dropbox. I realized Zima Files does not copy things like Finder Tags, so SMB is better for me and I’m not really using Files.
One other little thing I noticed with Zima Files: it doesn’t represent all characters correctly. For example, I have some Finder folders with “>” but that character does not show up.
Can you paste the name of the folder?Me.I’ll try.I tried not to.I’ll try.I tried withoutMy attempts didn’t reproduceIt didn’t reproduce when I tried
Despite the 1.2.5 update while copying from Google Drive, I encountered various problems and could not copy 100% of the files.
Do you want to copy from Google Drive, or do you want to copy from your local computer to Google Drive?
from google drive to my zimaOS raid
Hello Nico, thank you for your feedback. We have also noticed this issue. We are working on fixing this issue these days and it is expected to be fixed in the next version.
Hi Timothy,
@timothy @Nil0nl1n3
We have optimized the reliability of small-scale and medium-scale transmission scenarios in v1.3.1, and will continue to optimize the transmission reliability issues in large-scale data scenarios.
Would it be possible to add Box integration?
