Issue with Zima AI
Hello,
I’m writing to report some issues I’ve encountered with Zima AI. Since the latest update, it appears to have a noticeable impact on my server’s performance.
Here’s what I’ve observed:
  • Crashes of certain Docker containers (including Plex)
  • Full saturation of RAM
  • Full saturation of swap memory
At first, I couldn’t understand why my swap memory was constantly full and why the server was under heavy load. After some investigation, I eventually traced the problem to the Searchd process.
I then decided to disable Zima AI, and since doing so, everything has returned to normal — the server is running smoothly again.
Do you have any idea what might be causing this behavior?
Thanks in advance.
Thanks for your feedback. We are still improving the performance of searchd.
Thank you very much :slight_smile:
