Hello everyone
I´ve bought zimaos plus, but i had to format the installation, and then, when i´m trying to activate again, appears a message indicating something about it has been already activated in other service…. can you help me?
Regards in advance
Best option is to sent email from registered email address (the one you used when purchasing) to community@icewhale.org.
I had the same issue after reinstalling and it looks like it got something to do with boot change order or disk change etc.
Regards
Tom
Buenos dias,
todo solucionado hablando con soporte tecnico, muchas gracias!
De nada Rygar.
¿Te importaría hacer clic en la solución debajo de mi publicación?
Regards Tom
