Hi, there, I have spent a lot of time setting up my Plex from within Zima…In my Plex settings on the Zima, I have more than 40 Hosts/Containers under Volumes.
Is there a way to back up all this info in case something go’s wrong? I host Plex on the Zimaboard but leave my content on my Nas.
Thanks
Hi, may I know your user story?
If you place the user/config data and media file in the LAN sharing storage, you just need to mount them in your ZimaOS through the Files app. After that, you can configure the data storage location on the Docker apps’ settings panel. And in this situation, ZimaBoard will not affect your data. It just refers to all the data from the LAN sharing storage.
Really? I’ll be home in a few hours and will give it a go…Thanks very much, Ive only been into “Zima” going on about 6 weeks, so I’m still going through the learning curve. Thanks again…I’ll update you on my progress
