Is Bolt or v0 a better starting point for a small no-code app?
I’d like to build a small internal tool for a volunteer group here in New Mexico. Nothing special, just a form and a shared list that a few people can update. I’ve been looking at Bolt and v0 but I keep going back and forth on which one to start with, since both are aimed at people building apps from a description.
My main worry is that I’ll start down one path and hit a wall when it comes to connecting a real database, or that the free tier won’t be enough to figure out whether it works for us. I don’t have a strong coding background, so I care more about getting a working project than about fine control over every detail.
If you’ve used either for something small and practical, what made you pick it, and was there anything that surprised you once you got past the first draft? Any input is welcome.
Update after reading a bit more: Bolt vs v0 (2026): Which Should You Pick? laid out the database side more clearly. I’m leaning toward Bolt for the shared list, but I’m still unsure the free tier covers enough testing before we commit.
