Introducing "IceDash" for Zima OS & Casa OS
Hi @morgyann,
Thank you for testing again and for such a kind message.
I’m glad the media app worked, and that you can now change settings and add volumes from the ZimaOS interface. That was one of the main fixes in this version, so it’s good to hear it works on a real setup.
You’ve described the idea exactly. IceDash reads the store directly, so you always see the newest version of each app and you never have to update an imported store by hand. Getting the structure and the YAML in one click is also meant to help beginners. They can install an app first and learn how it works afterwards.
Please try as many store apps as you like, including the custom builds.
Good feedback is just as welcome. Thanks again for your time and your support.
