Intel Wi-Fi 7 BE200 not working on ZimaOS 1.8 — iwlwifi probe error -22
Hello,
I’m running ZimaOS 1.8 with kernel 6.18.9 and an Intel Wi-Fi 7 BE200 (320 MHz) adapter.
Hardware:
  • PCI ID: 8086:272b
  • Subsystem: 8086:00f4
  • Revision: 1a
The device is detected by lspci, but no Wi-Fi interface is created.
dmesg reports:
iwlwifi 0000:84:00.0: probe with driver iwlwifi failed with error -22
Kernel configuration:
CONFIG_IWLWIFI=m
CONFIG_IWLMVM=m
CONFIG_IWLMLD is not set
Running modinfo iwlmld returns:
Module iwlmld not found
Is Intel BE200 supported by ZimaOS 1.8? Is there a planned kernel or firmware update that enables the required driver support?
Thank you.
We will add this driver in the next version.
