I like to install, kicad as a doctor in the os I tried my best. I can’t do it. Is there any steps?
How to Install KiCad on ZimaOS
If you can’t find KiCad in the App Store, you first need to add the LinuxServer repository.
Step 1: Open the App Store
Open the App Store in ZimaOS.
Step 2: Add the Repository
In the top-right corner, click the drop-down menu next to the total number of apps (for example, 996 Apps).
Click More.
Select Add Repository.
Step 3: Paste the Repository URL
Copy the LinuxServer repository URL and paste it into the dialog.
Then click Add or OK.
Step 4: Wait for the Repository to Sync
Wait a minute or two while ZimaOS downloads and indexes the new repository.
Step 5: Search for KiCad
Go back to the App Store and search for KiCad.
Step 6: Install KiCad
Click Install and wait for the container to be created.
If KiCad doesn’t appear
Refresh the App Store.
Wait a few minutes for the repository to finish syncing.
If necessary, restart ZimaOS and search again.
After these steps, KiCad should be available in the App Store.
