I’ve been trying to download ZimaOs installer image (any version) and it keeps failing. I tried from home and work on different devices, and it still fails to download the whole .img file. Is the file available to download from an alternate location?
Please provide the screenshots of the error page.
Can you try this?
I was able to fully download this file without any issues. Thanks.
I would like to know if I can install and use it successfully?
Hi. I tried to create a bootable usb using balenaetcher but it says that the iso does not contain partition table
Are you able to host the .img file somewhere else please
This does not affect the installation, you can try to install it.
I have now tried both the slim iso and the beta img that you sent me and neither works. The Pc stops at the boot menu and does not go past that.
