Incorrect CPU core count and RAM frequency in Device Info across multiple ZimaOS versions
Hello,
I found hardware information display issues in Device Info on my system.
Hardware:
- CPU: AMD PRO A10-8770E
- RAM: 8 GB DDR4 SODIMM
- RAM manufacturer: Ramaxel Technology
I have observed these issues not only on ZimaOS 1.8.0-beta1, but also on previous versions, including ZimaOS 1.7.1, 1.7.0 and earlier versions.
1. CPU core count
Device Info shows:
AMD PRO A10-8770E R7, 10 COMPUTE CORES 4C+6G
1 Cores | 2.80 GHz | 4 Threads
However, Linux reports:
lscpu:
- CPU(s): 4
- Core(s) per socket: 4
- Thread(s) per core: 1
- Socket(s): 1
- CPU max MHz: 2800 MHz
Therefore, the CPU has 4 physical CPU cores and 4 threads.
The “1 Cores” value shown in Device Info is incorrect.
The “4C+6G” description appears to refer to 4 CPU cores + 6 GPU compute units, but the separate CPU core count is still displayed incorrectly as 1.
2. RAM frequency
Device Info shows:
8 GB
1066 MT/s
DDR4
Hardware information from the same system reports:
dmidecode:
- Size: 8 GB
- Type: DDR4
- Speed: 2400 MT/s
- Configured Memory Speed: 1066 MT/s
lshw:
- SODIMM DDR4 2400 MHz
- Size: 8GiB
- Clock: 2400MHz
This RAM frequency display issue is present across multiple ZimaOS versions, including 1.7.1, 1.7.0 and earlier versions.
Interestingly, the ZimaOS 1.8.0-beta1 release notes state that the issue where the memory frequency displayed in Device Info did not match the actual frequency was fixed.
However, on my system running ZimaOS 1.8.0-beta1, Device Info still displays 1066 MT/s.
Could you please investigate:
- Why Device Info reports 1 CPU core instead of 4?
- Which CPU topology information is being used by Device Info?
- Why Device Info displays 1066 MT/s for memory?
- Which SMBIOS field is being used for the RAM frequency?
- Why does the issue remain on 1.8.0-beta1 despite the release notes mentioning a fix?
I can provide the complete lscpu, dmidecode, lshw and dmesg outputs if needed.
Thank you.
Thank you for your feedback. We will make optimization adjustments for your hardware as much as possible.
Hi, thanks for the detailed report.
To help us investigate both issues, please connect to the affected system via SSH, run the commands below, and share the complete output.
jq '{cpu, memory, generated_at}' /run/zimaos/device-info.json
curl -fsS http://127.0.0.1/v2/zimaos/device/info |
    jq '{cpu, memory, os_version}'
sudo dmidecode -t 0 -t 1 -t 2 -t 4 -t 17 |
    sed -E '/Serial Number:|Asset Tag:|UUID:/d'
lscpu --json | cat
lscpu -a -p=CPU,SOCKET,CORE,ONLINE
cat /etc/os-release
cat /etc/release.yaml
uname -r
lscpu --version
dmidecode --version
sha256sum /usr/libexec/every-boot.d/06-generate-device-info
Hi,
I collected all the requested diagnostic information and included the complete output below.
ZimaOS Device Info Diagnostic Report
Generated: Mon Sep 28 05:09:38 PM CET 2026
===== device-info.json =====
“cpu”: {
"model": "AMD PRO A10-8770E R7, 10 COMPUTE CORES 4C+6G",
"packages": 1,
"cores": 1,
"threads": 4,
"frequency": "2.80"
“memory”: {
"slots_used": "1",
"onboard": false,
"total_byte": 8589934592,
"frequency": "1066 MT/s",
"type": "DDR4"
“generated_at”: “2026-09-26T14:45:08+01:00”
===== ZimaOS Device Info API =====
“cpu”: {
"cores": 1,
"frequency": "2.80",
"threads": 4
“memory”: {
"slots_used": "1",
"type": "DDR4"
“os_version”: “v1.8.0-beta1”
===== DMI / SMBIOS =====
# dmidecode 3.7
Getting SMBIOS data from sysfs.
SMBIOS 3.1.1 present.
Handle 0x0000, DMI type 0, 26 bytes
Platform Firmware Information
Vendor: LENOVO
Version: M1XKT63A
Release Date: 04/11/2024
Address: 0xF0000
Runtime Size: 64 KiB
ROM Size: 16 MiB
Characteristics:
	PCI is supported
	Firmware is upgradeable
	Firmware shadowing is allowed
	Boot from CD is supported
	Selectable boot is supported
	Firmware ROM is socketed
	EDD is supported
	5.25"/1.2 MB floppy services are supported (int 13h)
	3.5"/720 kB floppy services are supported (int 13h)
	3.5"/2.88 MB floppy services are supported (int 13h)
	Print screen service is supported (int 5h)
	Serial services are supported (int 14h)
	Printer services are supported (int 17h)
	ACPI is supported
	USB legacy is supported
	BIOS boot specification is supported
	Targeted content distribution is supported
	UEFI is supported
Platform Firmware Revision: 0.63
Embedded Controller Firmware Revision: 0.12
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: LENOVO
Product Name: 10VMS00600
Version: ThinkCentre M715q
Wake-up Type: Power Switch
SKU Number: LENOVO_MT_10VM_BU_Think_FM_ThinkCentre M715q
Family: ThinkCentre M715q
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Product Name: 3130
Version: NOK
Features:
	Board is a hosting board
	Board is replaceable
Location In Chassis: Default string
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0050, DMI type 4, 48 bytes
Processor Information
Socket Designation: AM4
Type: Central Processor
Family: A-Series
Manufacturer: Advanced Micro Devices, Inc.
ID: 51 0F 66 00 FF FB 8B 17
Signature: Family 21, Model 101, Stepping 1
Flags:
	FPU (Floating-point unit on-chip)
	VME (Virtual mode extension)
	DE (Debugging extension)
	PSE (Page size extension)
	TSC (Time stamp counter)
	MSR (Model specific registers)
	PAE (Physical address extension)
	MCE (Machine check exception)
	CX8 (CMPXCHG8 instruction supported)
	APIC (On-chip APIC hardware supported)
	SEP (Fast system call)
	MTRR (Memory type range registers)
	PGE (Page global enable)
	MCA (Machine check architecture)
	CMOV (Conditional move instruction supported)
	PAT (Page attribute table)
	PSE-36 (36-bit page size extension)
	CLFSH (CLFLUSH instruction supported)
	MMX (MMX technology supported)
	FXSR (FXSAVE and FXSTOR instructions supported)
	SSE (Streaming SIMD extensions)
	SSE2 (Streaming SIMD extensions 2)
	HTT (Multi-threading)
Version: AMD PRO A10-8770E R7, 10 COMPUTE CORES 4C+6G
Voltage: 1.0 V
External Clock: 100 MHz
Max Speed: 3600 MHz
Current Speed: 2800 MHz
Status: Populated, Enabled
Upgrade: Socket AM4
L1 Cache Handle: 0x004E
L2 Cache Handle: 0x004F
L3 Cache Handle: Not Provided
Part Number: Unknown
Core Count: 4
Core Enabled: 4
Thread Count: 4
Characteristics:
	64-bit capable
	Multi-Core
	Execute Protection
	Enhanced Virtualization
	Power/Performance Control
Handle 0x0052, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x004C
Error Information Handle: 0x0051
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: Unknown
Set: None
Locator: DIMM 0
Bank Locator: CHANNEL A
Type: Unknown
Type Detail: None
Handle 0x0054, DMI type 17, 40 bytes
Memory Device
Error Information Handle: 0x0053
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM 0
Bank Locator: CHANNEL B
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 2400 MT/s
Manufacturer: Ramaxel Technology
Part Number: RMSA3260ME78HAF-2666
Rank: 1
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
===== lscpu --json =====
“lscpu”: [
     "field": "Architecture:",
     "data": "x86_64"
     "field": "CPU op-mode(s):",
     "data": "32-bit, 64-bit"
     "field": "Address sizes:",
     "data": "48 bits physical, 48 bits virtual"
     "field": "Byte Order:",
     "data": "Little Endian"
     "field": "CPU(s):",
     "data": "4"
     "field": "On-line CPU(s) list:",
     "data": "0-3"
     "field": "Vendor ID:",
     "data": "AuthenticAMD"
     "field": "Model name:",
     "data": "AMD PRO A10-8770E R7, 10 COMPUTE CORES 4C+6G"
     "field": "CPU family:",
     "data": "21"
     "field": "Model:",
     "data": "101"
     "field": "Thread(s) per core:",
     "data": "1"
     "field": "Core(s) per socket:",
     "data": "1"
     "field": "Socket(s):",
     "data": "4"
     "field": "Stepping:",
     "data": "1"
     "field": "Frequency boost:",
     "data": "enabled"
     "field": "CPU(s) scaling MHz:",
     "data": "100%"
     "field": "CPU max MHz:",
     "data": "2800.0000"
     "field": "CPU min MHz:",
     "data": "800.0000"
     "field": "BogoMIPS:",
     "data": "5589.52"
     "field": "Flags:",
     "data": "fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good acc_power nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c lahf_lm cmp_legacy extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs xop skinit wdt lwp fma4 tce nodeid_msr tbm topoext perfctr_core perfctr_nb bpext ptsc mwaitx cpb hw_pstate ssbd ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 xsaveopt arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic vgif overflow_recov"
     "field": "L1d cache:",
     "data": "128 KiB (4 instances)"
     "field": "L1i cache:",
     "data": "192 KiB (2 instances)"
     "field": "L2 cache:",
     "data": "2 MiB (2 instances)"
     "field": "NUMA node(s):",
     "data": "1"
     "field": "NUMA node0 CPU(s):",
     "data": "0-3"
     "field": "Vulnerability Gather data sampling:",
     "data": "Not affected"
     "field": "Vulnerability Ghostwrite:",
     "field": "Vulnerability Indirect target selection:",
     "field": "Vulnerability Itlb multihit:",
     "field": "Vulnerability L1tf:",
     "field": "Vulnerability Mds:",
     "field": "Vulnerability Meltdown:",
     "field": "Vulnerability Mmio stale data:",
     "field": "Vulnerability Old microcode:",
     "field": "Vulnerability Reg file data sampling:",
     "field": "Vulnerability Retbleed:",
     "data": "Mitigation; untrained return thunk; SMT disabled"
     "field": "Vulnerability Spec rstack overflow:",
     "field": "Vulnerability Spec store bypass:",
     "data": "Mitigation; Speculative Store Bypass disabled via prctl"
     "field": "Vulnerability Spectre v1:",
     "data": "Mitigation; usercopy/swapgs barriers and \__user pointer sanitization"
     "field": "Vulnerability Spectre v2:",
     "data": "Mitigation; Retpolines; IBPB conditional; STIBP disabled; RSB filling; PBRSB-eIBRS Not affected; BHI Not affected"
     "field": "Vulnerability Srbds:",
     "field": "Vulnerability Tsa:",
     "field": "Vulnerability Tsx async abort:",
     "field": "Vulnerability Vmscape:",
===== lscpu CPU/Socket/Core/Online =====
# The following is the parsable format, which can be fed to other
# programs. Each different item in every column has an unique ID
# starting usually from zero.
# CPU,Socket,Core,Online
0,0,0,Y
1,1,1,Y
2,2,2,Y
3,3,3,Y
===== /etc/os-release =====
NAME=“ZimaOS”
BOARD=“ZimaCube”
VERSION=“v1.8.0-beta1”
ID=zimaos
VERSION_ID=1.8.0-beta1
PRETTY_NAME=“ZimaOS v1.8.0-beta1”
CPE_NAME=cpe:2.3:o:icewhale:zimaos:1.8.0-beta1:*:development:*:*:*:zimacube:*
VARIANT=“ZimaOS ZimaCube”
VARIANT_ID=zimacube
SUPERVISOR_MACHINE=ZimaCube
SUPERVISOR_ARCH=amd64
BUILD_DATE=“2026/09/24 11:03:43 UTC”
MANUFACTURER=“IceWhale Technology”
MODEL=ZimaCube
===== /etc/release.yaml =====
version: v1.8.0-beta1
build_date: 2026/09/24 11:03:43 UTC
===== Kernel =====
6.18.9
===== lscpu version =====
lscpu from util-linux 2.41.3
===== dmidecode version =====
3.7
===== Device Info Generator SHA256 =====
aa51de0fdb6623cb3116d67c9f16f13181ea96660c352c9878d423fd6753e98f /usr/libexec/every-boot.d/06-generate-device-info
End of report
The diagnostic results confirm the following discrepancies:
- CPU: ZimaOS Device Info reports 1 CPU core, while both lscpu and SMBIOS report 4 CPU cores and 4 threads.
- Memory: ZimaOS Device Info reports 1066 MT/s, while SMBIOS reports a memory Speed of 2400 MT/s. SMBIOS also reports Configured Memory Speed as 1066 MT/s.
- The issue is reproducible on my system running ZimaOS v1.8.0-beta1.
I have included the complete output of all the requested commands below for further investigation.
Thank you.
Thank you for providing the full diagnostics.
We have confirmed that showing “1 CPU core” in Device Info is incorrect. Your report lists four online logical CPUs, and SMBIOS reports four cores and four threads.
In the full lscpu output from your follow-up, the CPUs are grouped as “4 sockets, 1 core per socket.” The Device Info script multiplies lscpu’s cores-per-socket value by the processor count from SMBIOS, which produces 1 with these inputs. We have identified this core-count calculation issue and are investigating why Linux/lscpu reports four socket groups.
For RAM, Device Info displays the BIOS/SMBIOS Configured Memory Speed. This field is 1066 MT/s in your report, so the displayed value follows our intended behavior. The separate Speed: 2400 MT/s field is not the value used for this display.
To check whether “4 sockets, 1 core per socket” is consistently reproducible, please keep your current ZimaOS version and BIOS settings, restart the device normally two or three times when convenient, and run the following command over SSH after each boot:
lscpu
Please check whether Socket(s) and Core(s) per socket change.
If every reboot still gives Socket(s): 4 and Core(s) per socket: 1, please run the following command once over SSH after the final reboot to download and run the diagnostic script:
curl -fsSL ‘https://zimaos-image.oss-us-west-1.aliyuncs.com/test/collect-cpu-topology.sh?OSSAccessKeyId=LTAI5tNrA6heKFvGAPmmuSQu&Expires=1791533045&Signature=5%2FyNsR9e3eIZhhN2KBFFfUdOxVc%3D’ | sudo bash
The script only reads system information and creates one text report. It collects CPU logical and physical IDs, the kernel’s CPU groupings, BIOS information, and any accessible CPUID/APIC data and relevant boot messages.
When the script finishes, it prints the report’s full path. Please email that single zimaos-cpu-topology.*.txt file as an attachment to lvzhiyuan@icewhale.org. Please mention forum topic #9414, how many reboots you checked, and whether the results were consistent. If some sections are unavailable or skipped, please send the report anyway.
If the result changes after rebooting, for example to “1 socket, 4 cores per socket,” please first tell us what changed and whether the results alternate between reboots.
Also, please confirm whether ZimaOS is installed directly on the M715q hardware or is running inside a virtual machine.
This information will help us identify the source of the unexpected socket grouping. Thank you for your help.
Hello,
I would like to provide a follow-up to my previous email regarding forum topic #9414.
I restarted the Lenovo ThinkCentre M715q four times and ran `lscpu` after each reboot.
The result was consistent after all four reboots:
- CPU(s): 4
- On-line CPU(s) list: 0-3
- Socket(s): 4
- Core(s) per socket: 1
The CPU topology did not change between reboots. It consistently reports 4 sockets with 1 core per socket.
I have also already sent the requested `zimaos-cpu-topology.*.txt` diagnostic report to the email address you provided.
ZimaOS is installed directly on the Lenovo ThinkCentre M715q hardware and is not running inside a virtual machine.
Thank you for your help and investigation.
Best regards,
I installed zimaos on a PC with an AMD processor but apparently ziamos reads the AMD kernel sensors incorrectly and I find the temperature of one of my 2 nvme as the CPU temperature. It’s not good. These are mine hwmon:
=== /sys/class/hwmon/hwmon0 ===
nvme
Composite
temp1_input: 52850
=== /sys/class/hwmon/hwmon1 ===
nvme
Composite
Sensor 1
Sensor 2
temp1_input: 49850
temp2_input: 49850
temp3_input: 47850
=== /sys/class/hwmon/hwmon2 ===
k10temp
Tctl
temp1_input: 47125
=== /sys/class/hwmon/hwmon3 ===
amdgpu
edge
temp1_input: 43000
there is a possibility to fix it and to be precise it is :
AMD Ryzen 5 PRO 4650GE with Radeon Graphics
6 Cores3.30 GHz12 Threads
