Immich does not update
I have ZimaOS version 1.6.0 beta2. I've noticed several versions of Immich coming out recently, but even though I tell it to update Docker, it doesn't update. What can I do?
Hi, have you looked here and see if it works for you?
I'm using the BigBear version, and I've changed the version in the Docker configuration, but it still won't update. I've been thinking about backing up Immich, uninstalling Docker, and reinstalling it, but I'm worried that a database key might malfunction and I'll lose my photos. I don't know if you recommend this, or if you know the location where the photos are saved so I can back them up and then import them again.
What do you recommend?
