I keep losing access to ZimaCube after 24 hours. Need suggestion Please
After over a year of no issues, I now have an odd problem where I’m unable to access my ZimaCube after approximately 24 hours. I then have to power it off and then on. As far as I can tell, when I go into my router, it is connected the whole time. I just can not access it from the web browser, phone, file explorer, etc after a 24-hour period. It only started doing this after I had a power outage last week. Before that, it’s been over a year of flawless zero-error operation. Im running ZimaOS v1.4.1 Router is a MSI GRAX66 Connect via 2.5gbps port
Here’s what I tried so far…
a router restore from a backup I created a year ago.
Remove the ZimaCube from static IP and put it on DHCP.
(Did this both in the router settings and on the ZimaCube settings.)
Put it back on static IP with a different IP #
I need suggestions please, or my next step is a factory reset on the Zima Cube, and a factory reset on the router. Really trying to avoid this. Thanks in advance.
We will support you in private messages. Please check your message box.
Just want to put a quick update in case anyone comes across this post in the future. Support was able to resolve this. The solution was to turn off AI search feature… Big shout out to support, thank you so much!!
