I just installed Hugo and it will not start. I am on the current 1.8 release. Where are the logs to look at?
If you are talking about the static site generator, then it is not meant to start per se but, through a shell command, to generate, based on a template, a (static) website which is eventually served with a web server (caddy, apache…). Note that it also has an embedded web server but that’s essentially for local testing purpose.
If it’s something else you’re talking about, then can you be more specific please ?!
OK it is a documentation error and a user error. I though it had to be started. You install the “app” and click on start it. Needs to have better documentation so that others do not make the same mistake.
Well, Hugo is indeed a nice tool to generate fast loading websites but, if you’re not equipped with a developer mindset you will surely struggle a bit. Yet, you could add a code editor and, more importantly, a CMS (Content Management System) to your setup in order to have a complete (integrated) environment ![]()
