How to update the system
Hello. how can I update the system Zima OS. Thank you
There are two main ways.
The first way, wait for the system to prompt you. The notification will show up in the settings panel.
The second way, do it manually.
Tips:
If your version is too old, like below 1.2.5, please update to 1.2.5 manually and then update to 1.4.1.
