In ZimaOS version 1.2.5, Windows LAN device discovery and DLNA services have been added, which may occupy port 1900 of Jellyfin. You can follow the steps below to disable the related services:
The reason for this issue is our new service for UPNP device broadcasting, which occupies port 1901, which is mainly used for the discovery of Windows network devices. The reason for the failure after the reboot should be that the SSDPD service is not really disabled.
Anyway, we are aware of this problem and have moved the 1901 port of the ssdpd to a different port, this issue will be fixed in the next release, until then you may still need to manually execute systemctl stop ssdpd.service after boot I hope you understand.
