Hi, how can I report or send corrections to the italian translation?
Some entries are not translated or there are translation errors, for example “Spazzatura” (which also creates an ugly visual effect) instead of “Cestino”.
Looks like IceWhale is primarily handling translation work through discord. There is a channel for ZimaOS translations there.
Thanks!
I also noticed the same translation error. Thank you for pointing it out.
