How to reinstall CasaOS
I’ve prepared a script that simplifies the process of reinstalling CasaOS, and I’m excited to demonstrate how to use it in a video tutorial. This script utilizes the default CasaOS scripts to execute both the uninstallation and reinstallation steps, making the whole process straightforward.
nice tutorial but i’m getting error while trying to install:
~$ curl -fsSL https://get.casaos.io | sudo bash
curl: (60) SSL certificate problem: certificate has expired
More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
is this a common issue i read that icewhale sometimes forget to renew the certificate.
Sup,
You need to pass the -k or –insecure option to the curl command.
More here: https://www.cyberciti.biz/faq/how-to-curl-ignore-ssl-certificate-warnings-command-option/
Much love. Peace.
What a guy…
It took me a min to find Big Bears script he was talking about. It’s here: big-bear-scripts/reinstall-casaos at master · bigbeartechworld/big-bear-scripts · GitHub
I’m going to give it a try as I need to reinstall casaos on my zimaboard and mod it to use the sata drive and not the integrated 32g drive. I’ll post here any mods/changes I do IF I’m successful.
I have a ton of photos under Immich container. Is it possible to reinstall CasaOS, without loosing my very precious gallery? Creator of this post indirectly suggests that reinstaller doesn’t need to touch container or collected data.
Anyone tried doing something similar?
