How to mount remote SMB share via Tailscale on ZimaOS?
Hello,
I’m trying to set up remote backups between two machines and I’ve run into an issue after switching to ZimaOS.
Setup:
  • ZimaBlade running ZimaOS (source machine).
  • Remote server running CasaOS (target machine, exports SMB share).
  • Both are connected via Tailscale.
Problem:
  • When both machines were running CasaOS, I could install Tailscale directly on the host, mount the remote SMB share on my ZimaBlade, and use it as a backup target.
  • On ZimaOS, I can only run Tailscale inside Docker. That container joins the tailnet, but the host OS (and Files app) don’t see the Tailscale network → I can’t mount the SMB share anymore.
Question:
  • Is there a supported way to run Tailscale at the host level on ZimaOS?
  • Or, how can I configure the Docker Tailscale app so that SMB shares from the remote CasaOS server can be mounted in the ZimaOS Files app?
So after searching some more I decided to switch how I am doing things.
I used :
curl -s https://install.zerotier.com | sudo bash
sudo zerotier-cli join <RemoteID>
on my remote CasaOS server so that it joins the ZeroTier Network of my ZimaOS and therefore can acess the smb share on this. Works well.
