How to mount a share folder for Plex
Glad it worked out. Enjoy.
Thanks for that!
For any new user their PUID is „computed“ with X - 1.
first user (admin) PUID = 999
root PUID = 0
So the second user would get the PUID 998, the third user 997, fourth user 996….
How did you get the synology drive to be in the media folder? When I connect mine via the files app it automatically is added as its own mapped nextwork drive. I can view all the media files in the files app. When i copy the path the files app provides in the settings of either plex or jellyfin to add a volume it always fails and says the bind doesnt exist.
Any insight would be much appreciated.
Also if i change the PUID to 999 it will no longer load either plex nor Jellyfin they error out when launched
For anyone else who seems to have the same issue I did. I had to star the folders in the network drive within the zima files app before they would show up in the mapping tool for both plex and jellyfin.
Would you please read this carefully?
Thank you. This is the solution I needed!
