I use this code to run Tailscale
services:
tailscale:
cap_add:
- NET_ADMIN
- NET_RAW
container_name: tailscale
environment:
- TS_AUTHKEY=tskey-auth-kNL***
- TS_HOSTNAME=zimaos
- TS_ROUTES=
- TS_STATE_DIR=/var/lib/tailscale
image: tailscale/tailscale:v1.84.3
labels:
icon: https://cdn.jsdelivr.net/gh/IceWhaleTech/CasaOS-AppStore@main/Apps/Tailscale/icon.png
restart: unless-stopped
volumes:
- /DATA/AppData/tailscale:/var/lib/tailscale
- /dev/net/tun:/dev/net/tun
network_mode: host
privileged: false
But every time I reboot my OS or change settings in app, it creates new machine in Tailsalce admin panel. Is there a way to lock this container to always create the same machine in Tailscale admin panel?
Happens when Tailscale can’t reuse its machine key—usually because the container isn’t actually persisting /var/lib/tailscale (or it’s owned by the wrong user), or because it re-auths each boot.
Make sure the state folder exists and is root-owned
mkdir -p /DATA/AppData/tailscale/state
chown -R 0:0 /DATA/AppData/tailscale
chmod -R 700 /DATA/AppData/tailscale
Use this Compose (persistent state, stable hostname; no extra privileges)
services:
tailscale:
network_mode: host
cap_add:
- NET_ADMIN
- NET_RAW
devices:
environment:
# Use a reusable (non-ephemeral) key only for the first start.
TS_AUTHKEY: tskey-auth-REPLACE_ME
TS_HOSTNAME: zimaos
TS_STATE_DIR: /var/lib/tailscale
volumes:
- /DATA/AppData/tailscale/state:/var/lib/tailscale
Deploy. After it shows in the Tailscale admin, remove the TS_AUTHKEY line in the editor and redeploy so it reuses the same machine ID forever.
For me everything was done already, I just had to delete auth key environment variable. Looks like now it persist machine name.
Thank you.
