Discover How to Install WordPress on CasaOS using BigBearCasaOS!
In this tutorial, we’ll walk you through the process, step by step, ensuring you’re set up and ready to go in no time.
I am interested in installing wordpress but have CasaOS installed on a raspberry pi 4 and it says “Not compatible with arm64 devices”. Is there another way around this to run wordpress?
Can you try it again? I did add support for arm64.
Hello @dragonfire1119. I really like CasaOs. I have run on an RPI4. I’m in need to install Wordpress usung BigBearCasaOs, but I get error "no matching manifest for linux/arm/v8. You have mention on this topic, to @Nexusone309, that should try again installing WordPress, having similar error with mine, as you have added support for arm64. Will you be kind enough to sharehttps://community.zimaspace.com/u/ with me the add file, with arm64 support for Wordpress using BigBearCasaOs?
