How to increase memory for Virtual Machine?
I tried to install Zorin as a VM in ZVM. The installation started but was interrupted with the failure-message “Zorin needs 15 GB of memory; the server only has 10 GB”
Only choices: return or abort the installation.
How and where can I allocate 15GB of Memory for a Virtual machine?
I found the solution: When selecting to “add new VM” then you get a pop-up where you select the OS to install. On the same pop-up you can change the memory size (default is 10GB → you can change to 15 GB or up to 217 GB). Problem solved.
