How to get SHM size increased running frigate in ZimaOS+ 1.7.0
Trying to figure out how to increase the SMZ size for Frigate app running it ZimaOS+.
I have tried from Frigate forum instructions but can’t find where to do in ZimaOS.
In your docker yaml for frigate. I have it setup as follows:
services:
frigate:
cpu_shares: 90
command:
container_name: frigate
deploy:
resources:
limits:
memory: 8197627904
reservations:
devices:
devices:
  • /dev/bus/usb:/dev/bus/usb
  • /dev/apex_0:/dev/apex_0
  • /dev/dri/renderD128:/dev/dri/renderD128
    environment:
  • FRIGATE_RTSP_PASSWORD=
    image: ghcr.io/blakeblackshear/frigate:stable
    labels:
    ports:
  • target: 8554
    published: “8554”
    protocol: tcp
  • target: 8555
    published: “8555”
    protocol: tcp
  • target: 8555
    published: “8555”
    protocol: udp
  • target: 8971
    published: “8971”
    protocol: tcp
    privileged: true
    restart: unless-stopped
    shm_size: “268435456”
    stop_grace_period: 30s
    volumes:
  • type: bind
    source: /etc/localtime
    target: /etc/localtime
  • type: bind
    source: /DATA/AppData/frigate/config
    target: /config
  • type: bind
    source: /media/storage1/frigate
    target: /media/frigate
  • type: tmpfs
    target: /tmp/cache
    tmpfs:
    cap_add:
    network_mode: bridge
    x-casaos:
    author: self
    category: self
    hostname: “”
    index: /
    is_uncontrolled: false
    port_map: “8971”
    scheme: https
    store_app_id: frigate
    title:
    custom: “”
    en_us: frigate
Sorry for the messed up layout, I’m pasting this from my phone. Note the shm_size tag. Put that in your own yaml and configure to your needs.
Ok that did not work, but I found how to get it in.
In Zima frigate Settings< Advanced< In (form) I used Environment Variables: Name<shm_size>Value:<“268435456”> for 256MB. This worked and now shows up in the yaml under entry point environment:
Now my other issue is: frigate.comms.mqtt
Message
Unable to connect to MQTT server: Invalid host.
I have MQTT enabled: true in frigate config, bu tget that error.
And I noticed you have port 8971 UDP in that config, is that for mqtt?
I have MQTT installed in Zima but I don’t know what settings in either Frigate or MQTT to set.
Here is MQTT yaml:
services:
  mosquitto:
    command:
      - sh
      - -c
        if [ ! -f "/mosquitto/config/mosquitto.conf" ]; then
          echo -n "No config file found. Create one... "
            echo "# config generated on $(date +%Y.%m.%d\ %H:%M:%S)"
            echo "allow_anonymous true"
            echo "listener 1883"
            echo "persistence true"
            echo "persistence_location /mosquitto/data/"
            echo "log_dest file /mosquitto/log/mosquitto.log"
          } > /mosquitto/config/mosquitto.conf
          if [ $? -eq 0 ]; then
            echo "done."
          else
            echo "error."
            exit 1
          fi
        fi
        echo "Starting Mosquitto"
        /usr/sbin/mosquitto -c /mosquitto/config/mosquitto.conf
    container_name: mosquitto
    deploy:
      resources:
        limits:
          cpus: "0.20"
          memory: 1.09GB
        reservations:
          cpus: "0.00"
          memory: 512MB
      placement: {}
    entrypoint: null
    image: eclipse-mosquitto:2
    labels:
      icon: https://raw.githubusercontent.com/mr-manuel/CasaOS-HomeAutomation-AppStore/latest/Apps/Mosquitto/icon.png
      traefik.enable: "false"
    ports:
      - target: 1883
        published: "1883"
        protocol: tcp
    privileged: true
    volumes:
      - type: bind
        source: /DATA/AppData/mosquitto/config
        target: /mosquitto/config
      - type: bind
        source: /DATA/AppData/mosquitto/data
        target: /mosquitto/data
x-casaos:
  architectures:
    - amd64
    - arm64
    - arm
  author: mr-manuel
  category: Home Automation
  description:
    en_us: >
      Visit [Eclipse Mosquitto](https://mosquitto.org) for more details. Check
      the [documentation](https://mosquitto.org/documentation/) for further
      settings.
  developer: Eclipse Mosquitto
  main: mosquitto
  port_map: "1883"
  project_url: https://github.com/mr-manuel/CasaOS-HomeAutomation-AppStore
  repo_id: github.com@0842c82b
  store_app_id: mosquitto
  tagline:
    en_us: >
      Eclipse Mosquitto is an open source (EPL/EDL licensed) message broker that
      implements the MQTT protocol versions 5.0, 3.1.1 and 3.1. Mosquitto is
      lightweight and is suitable for use on all devices from low power single
      board computers to full servers.
  thumbnail: https://raw.githubusercontent.com/mr-manuel/CasaOS-HomeAutomation-AppStore/latest/Apps/Mosquitto/icon.png
  tips:
    before_install:
      en_us: >
        The MQTT broker will be reachable at port `1883`.
        [Website](https://mosquitto.org) &bull;
        [Documentation](https://mosquitto.org/documentation/)
  title:
    custom: Mosquitto
    en_us: Mosquitto
And now here is Frigate yaml:
# config generated on 2026.07.21 13:18:05
mqtt:
  enabled: true
detectors:
  coral:
    type: edgetpu
    device: usb
ffmpeg:
  hwaccel_args: preset-nvidia
cameras:
  Office:
    ffmpeg:
      inputs:
        - path: rtsp://xxxxxxxxx:554/12
          roles:
            - detect
        - path: rtsp://xxxxxxxxx/11
          roles:
            - record
    detect:
      enabled: true
      width: 640
      height: 352
      fps: 5
    motion:
      threshold: 30
      contour_area: 12
      improve_contrast: true
    zones:
      office-door:
        coordinates: 0.395,0.085,0.637,0.091,0.512,0.997,0.348,0.953
        inertia: 10
        loitering_time: 3
        objects: person
    review:
      alerts:
        required_zones: office-door
      detections:
semantic_search:
  enabled: true
  model_size: small
face_recognition:
  enabled: true
  model_size: small
lpr:
  enabled: true
classification:
  bird:
    enabled: false
version: 0.17-0
