please tell me how to enable https:// ?? I would also like ZM to have the ability to create multiple HDD disks with the ability to select IDE, SATA, and the ability to import and export as in Virtual Box. I would really like to see a full-fledged web server for deploying my HTML sites, SMS. I also really need a DDNS connection with the ability to select providers or add my own provider. I like Zimaos and I would really like to see these features in it as in the older models of Asustor, Qnap, Synology.
Hi
You may want to say what hardware you are using.
Many of the idea you suggest may have been implemented, have you looked at the Discord server?
Thank you ! Unfortunately Discord is blocked in my country. Are there other resources or forums where I can read information?
Sorry not really.
Many people post here but are more active on Discord, as that where the support channels first started.
