I’ve created a script to modify the CasaOS port via the command line, and I will also guide you on how to change the port through the user interface. This way, you have two options for adjusting the CasaOS port.
Hi, thank you for the excellent tutorials. Could you please create a tutorial on how to check/set the appropriate permissions in Collabora Document Server installed in the NextCloud? The NextCloud is installed within CasaOS. Thank you in advance, Z.
Sure I will put it on my Todo List.
