How to Automate Backups From RAID 0 SSDs to Removable HDDs on ZimaOS
Hello, I’m looking for help with the different backup solutions offered by ZimaOS.
I have a ZimaCube Pro with a 10 GbE connection. To fully take advantage of 10 GbE, I plan to create a RAID 0 using several DC600M 7.68 TB SSDs that I already own. I need this speed for my professional activity. However, the risk of disk failure or data corruption is still present. So I would like to use several 26 TB Western Digital Gold HDDs that I already own as a backup for the RAID 0.
My question is the following: once my RAID 0 is created with my SSDs in ZimaOS, how can I set up a daily synchronization or a sync after each change from the RAID to the HDD? Does ZimaOS include a built-in option for this, or is there a recommended app to install?
Additionally, I would like to be able to easily swap the HDDs. I have multiple 26 TB drives. I want to keep multiple copies, one in the ZimaCube and one off-site. I want to rotate them every 3 or 4 months.
Is there an app that supports this workflow and can automatically continue the synchronization from the RAID? Or would a RAID 1 on the HDDs be a better approach?
I’m looking forward to your suggestions.
I believe your design is solid and very professional: RAID 0 SSDs for maximum performance, backed up to rotated large HDDs for resilience and off-site protection. That’s exactly how this is handled in many production environments.
At the moment, I think it’s important to set expectations clearly: ZimaOS does not support real-time or “sync on every change” replication between storage pools. The built-in Backup app is scheduled only. Because of that, I suggest focusing on fast, scheduled synchronization, which already gives excellent protection when paired with RAID 0.
For your workflow, I believe rsync is the best tool. It’s reliable, fast, and handles disk rotation extremely well.
Recommended workflow (simple and robust)
I suggest:
  • RAID 0 SSD pool as your source
  • Each 26 TB HDD as a standalone backup target (no RAID)
  • Nightly rsync job
  • Rotate HDDs every few months
    When a disk is swapped, rsync simply reconciles differences and continues, no rebuilds, no complexity.
I do not recommend RAID 1 on the HDDs for this use case. RAID complicates rotation and removes the benefit of each disk being a complete, portable backup.
Simple rsync container layout for ZimaOS
This is intentionally minimal and safe.
1. Folder layout on ZimaOS
Create a small config directory:
/DATA/AppData/rsync-backup/
├── backup.sh
└── crontab
2. backup.sh (the actual sync logic)
Example script:
#!/bin/sh
SOURCE="/DATA/SSD_RAID"
TARGET="/DATA/Backup_HDD"
rsync -avh --delete --numeric-ids \
  --inplace \
  --stats \
  "$SOURCE/" "$TARGET/"
What this does:
  • Mirrors SSD RAID to HDD
  • Deletes removed files (true mirror)
  • Preserves permissions and ownership
  • Runs fast on large datasets
Make it executable:
chmod +x backup.sh
3. crontab (daily schedule)
Example: run every night at 2 AM
0 2 * * * /config/backup.sh >> /config/rsync.log 2>&1
4. Docker container setup
Use a lightweight base image (Alpine works well).
Container settings:
  • Image: alpine
  • Network: bridge
  • Restart policy: unless-stopped
Volumes:
  • /DATA/SSD_RAID > /DATA/SSD_RAID
  • /DATA/Backup_HDD > /DATA/Backup_HDD
  • /DATA/AppData/rsync-backup > /config
Command:
sh -c "crond -f"
Install rsync once inside the container:
apk add rsync
5. Rotating HDDs
When you swap disks:
  • Mount the new HDD to the same path (/DATA/Backup_HDD)
  • Start the container
  • rsync automatically continues and reconciles differences
Each HDD remains:
  • Fully readable on any Linux system
  • Independent
  • Safe to store off-site
Final thoughts
I believe this gives you:
  • Full 10 GbE SSD performance
  • Clean, predictable backups
  • Easy disk rotation
  • No vendor lock-in
  • No RAID rebuild risks
This setup is simple, proven, and very well suited to ZimaOS as it exists today.
Thanks a lot for the super detailed reply, it’s genuinely helpful and clears up a lot :+1:
I do have a few follow-up questions though:
1) Difference vs ZimaOS built-in Backup (Auto mode)
How does your approach (rsync + cron + container) differ from the Backup feature already built into ZimaOS, especially the Auto mode?
In the UI it says: “When the source is Zima Storage or a USB drive, backups run instantly whenever a file changes.”
So I’m wondering: doesn’t this already behave like “sync on every change” (or close to it)? If not, what’s missing / what makes rsync the better option for my use case?
2) Rsync with a GUI
Is there any rsync solution with a GUI that can be installed (ideally from the ZimaOS App Store)? I didn’t find anything there, and I’d prefer not to manage everything purely via command line if possible.
3) HDD rotation while using the same bay
Ideally I want to rotate my backup HDDs by swapping them in the same bay, so I never have an empty bay and I don’t have to keep reconfiguring paths each time.
Does ZimaOS (or rsync with your setup) automatically understand that the drive inserted in that bay is a different disk, and then restart an incremental backup correctly?
For example: I reinsert a drive that hasn’t been synced for 3-4 months, so its backup state is older and “out of date” compared to the SSD RAID0. I want this to be fully automatic: swap the drive, and it resumes by reconciling differences (not starting from scratch).
Thanks again!
