How install coral apex drivers pci working for Frigate on ZimaOS
Thanks @GavinBaker !!
@Zima-Jerry It shows as follows for me:
Bus 002 Device 002: ID 1a6e:089a Global Unichip Corp.
Please also note that the VID/PID may change!
Coral USB devices use specific Vendor ID (VID) and Product ID (PID) combinations, typically 1a6e:089a (Global Unichip Corp.) for initial detection, but they can switch to another ID like 18d1:9302 (Google Inc.) after initialization or for specific functions, which helps systems identify the Edge TPU accelerator for AI tasks
Initial/Boot VID/PID: 1a6e:089a (Often seen as Global Unichip Corp.).
Runtime/Active VID/PID: 18d1:9302 (Often seen as Google Inc.).
Hi Jerry,
Thank you for clearing up that point. I was wondering why occasionally I would see it as the Google Inc. entry you described above.
Many thanks to you and your team for all the help and a great product.
Gavin Baker.
Hi, I found a solution from Sir Will, that seems to work. I have included the link below.
Many Thanks,
Gavin Baker.
