Hi I'm new and I have some issues
Hi everyone I’m new to Zima OS I grabbed the pro it cost me $40 Canadian
Now I have some concerns
Right now I have three storage mediums
I have the boot disk which is 120 GB SSD
I don’t wish to have any data on that except the base OS
Next I have a raid 5 where I want all my main data to sit
I want my containers here as well as their data
I also want to put any other files that I deem fit in that area as well including my downloads
Then I have a two terabyte scratch disc that I want to use for miscellaneous storage
I want to know how I can set this up so that it runs properly
Also I hate the current file Explorer Program
I absolutely detest it
Is there an alternative that will work flawlessly
I want to use this basically as a container server
With extra storage if needed on that 2 TB Drive
Also I have four servers
Two Synology are 4800 ugreen and this one running Zima
Is there a way I can set up some type of file share between all four
Without jumping through hoops
But I also want to be able to cut and paste like I do in Windows
Appreciate the help and this looks like a really good start to an OS
Thanks
Tom
You’re actually thinking about the storage layout the right way — most people running ZimaOS as a container server end up doing something very similar.
Your boot SSD (120GB) should ideally stay for ZimaOS only. Avoid putting containers or data there if possible.
Your RAID-5 array is the correct place for containers and persistent data. A common approach is to store all container volumes under something like:
/DATA/AppData/container-name
This keeps all Docker configs and data on the RAID and not on the OS disk.
Your 2TB drive can simply be mounted as a secondary location for things like downloads, temporary files, media staging, or anything that doesn’t need to live on the RAID.
So the layout conceptually becomes:
Boot SSD > ZimaOS only
RAID-5 > containers + persistent data
2TB disk > scratch / temporary storage
Regarding the file explorer, you’re not the only one who dislikes the built-in one. Many users run FileBrowser in Docker as a replacement because it’s lightweight and supports normal drag-and-drop and copy/paste style file management.
If you want more specific advice, it would help to know where your RAID and 2TB disk are currently mounted. You can check with:
ls /DATA
or
mount
Once we see the mount paths, it’s easier to recommend the cleanest folder structure.
thanks
