i want to stop using zimacube remote it just zerotier but i want to remove the icewhale RemoteAccess in the zerotier i can let it leave but after reset its back i dont want this privacy
Zerotier is a pre-installed function. Therefore, when you reset system, it will come back.
can i remove the pre install data
We are discussing a function that offers a list of apps, allowing you to choose which to use or delete during system installation.
If we achieve any results, you will be reminded here.
If you just don’t want “anyone to be able to access your ZimaCube through Zerotier”, you can turn off the switch in the following settings
sorry but that way you cant use your private zerotier
any update for private zerotier?
Sorry. But Zerotier is indeed private to you. And you can reset the remote ID any time you want.
For more security knowledge, refer to
