Before we get to the main topic, please fix the issue where the capacity becomes 20PB when creating RAID 1 using two 20TB HDDs.
The HDD used was SEAGATE IronWolf Pro.
Now, onto the main topic. Even though I’m not accessing the NAS, the HDD is frequently reading and writing.
Even if I leave the power on for several days and disconnect the LAN, the HDD is always being accessed.
Is there a reason or setting that is causing this?
Also, is there a sleep mode for the HDD when the NAS is not being accessed?
Hello, thank you very much for your 20PB feedback, we have recorded it and will fix it immediately. At the same time, the hard disk hibernation function will be implemented in the next version zimaos1.2.5! The beta version will be released this week. If you are interested, can I invite you to enter the beta version?
Thank you for your reply.
I’ll try it out when the beta version is released.
Hello, the test version has been released.
Please enter “channel-tool public” in the command line and restart and wait for the new update to pop up.
you can open this app to enter command:
If you find this troublesome, we plan to release the official version of zimaos1.2.5 next week, and you can update directly then!
After installing the beta version, my HDD became more power efficient.
Thank you very much.
