Hauppauge SoloHD Tuner Missing Firmware?
Is there currently a trick to getting this tuner to work, I bought a License for ZimaOS today because everywhere I read said it was supported. The device is detected but I can’t import the firmware because read only filesystem.
dmesg | grep -i si2168
[ 7.069951] si2168 9-0064: Silicon Labs Si2168-D60 successfully identified
[ 7.069952] si2168 9-0064: firmware version: D 6.0.1
[ 7.078835] em28xx 1-10:1.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)…
[ 7.078838] dvbdev: dvb_create_media_entity: media entity ‘Silicon Labs Si2168’ registered.
[ 923.164269] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 923.164274] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 1135.832725] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 1135.832759] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 1507.642767] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 1507.642772] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 1507.646787] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 1507.646791] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 1825.887765] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 1825.887770] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 2076.923242] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 2076.923259] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 3361.403379] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 3361.403386] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 3409.845294] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 3409.845299] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
[ 3409.849448] si2168 9-0064: Direct firmware load for dvb-demod-si2168-d60-01.fw failed with error -2
[ 3409.849452] si2168 9-0064: firmware file ‘dvb-demod-si2168-d60-01.fw’ not found
is this an I’m still a noob problem or just a shit out of luck (hopefully only temporarily) scenario?
