Grayed out drive cannot be selected for Raid expansion
ATM i am running a 4x4tb setup and after upgrading to ZimaOS Plus and rebooting i tried to add a 4tb drive to my Raid5 setup to expand the pool. Now i can see the drive listed in the GUI but cannot select it for expansion. It is grayed out and does not behave like the last drive i added a while back goung from 3 to 4 drives.
Maybe also important is that the other drives are all WD Blue drives and the new one is a WD Green. Does that make a difference? And if not how do i fix this issue?
Hi, to help others understand and respond quickly, please fill out the template below.
Description
Explain what’s happening in simple terms.
Steps to Reproduce
List the exact steps that lead to the issue.
(Screenshots are helpful, videos or screen recordings are even better.)
Expected vs Actual Behavior (optional)
What you expected to happen, and what actually happened.
Before It Happened
Mention any changes or actions performed before the issue appeared.
Troubleshooting Tried
Describe what you’ve already done to fix it.
(Include visuals if possible.)
System Details
Add your hardware specs, ZimaOS version, Zima client version, and Client OS version.
You are suggested to make this permanent: Preferences > Profile > About Me. Recommended format:
ZimaCube | N150 | 64GB | 990 Pro | RTX 2000 | ZimaOS 1.5.1
Thank you for taking the time to include these details, and it helps everyone resolve issues faster and keeps the community running smoothly.
