Hello,
I come from synology and the hyper backup allows for a full system backup, including all folders, all applications and system settings.
So, when migrating to a new synology box, you can start up hyper backup on the new system, point it to the backup and it will fully restore everything.
I’ve done that several times being a 20+ year synology user.
A few months ago I got the zimaboard2 and have been migrating my websites to this.
It was a bit of a learning curve, it still is.
Now, I searched on the forum but did not find a clear answer.
Like if I were to buy a ZimaCube, how would I transfer my existing system?
Also, would all docker apps with volumes and what else be restored ?
Thanks for clarification,
Christian
I believe your understanding is correct and aligns with current best practice.
ZimaOS does not offer a Hyper Backup–style full system restore or DSM migration. It’s a different architecture, designed around a lightweight OS and Docker with data living on disk.
I suggest treating a Synology → ZimaOS move as a data-only migration:
- Copy data over LAN (SMB or rsync)
- Migrate files, media, and database exports only
- Avoid restoring DSM apps, settings, or system backups
On ZimaOS, I suggest:
- A fresh install
- Recreating services as Docker containers
- Restoring data under
/DATA and /DATA/AppData
- Adjusting ownership via the Files app if required
This approach avoids compatibility issues and matches what’s recommended in ZimaOS documentation and community discussions.
I’m checking how well synology active backup for business would work to make a full copy of my zimaboard system including all attached drives.
I did that for my yunohost server and it runs automatic and daily.
I would have to install the linux client which is available for debian systems.
now , the big question: wouldn’t that interfere with zimaboard2/zimaOS ?
My synology is still in use (DS1513+) with 60TB of storage and could run for the next ten years, so , yes, I would like to continue use it for backup and my zimaboard as a webserver/appserver
Any thoughts?
Christian
I believe your assessment is sound.
ZimaOS is built as a lightweight, mostly immutable system (SquashFS + OverlayFS) with a strong focus on Docker and data living under /DATA. Because of that, I suggest not installing Synology Active Backup for Business agents on ZimaOS. System-level backup agents are likely to conflict with the overlay filesystem, Docker storage layers, and ZimaOS update/rollback mechanisms.
I suggest continuing to use your Synology as a backup destination, not as a system controller:
- Back up
/DATA (especially /DATA/AppData) from ZimaOS to Synology
- Use file-level methods like SMB, rsync, or the ZimaOS Backup app
- Let ZimaOS handle OS recovery via its own rollback or a clean reinstall if ever needed
This keeps things clean and safe: Synology for long-term storage and backups, ZimaOS for apps and services, without introducing unnecessary risk.
