I’ve been running my ZimaCube now for nearly two weeks.
Few bugs (using Safari):
- Display problems
- not all buttons like ‘ok’, ‘continue’ display correct
- you need to know where the button is - then it will show
- SMB disconnecting
- I’ve been transferring files for the past couple of days. Every morning when I come to my office - the SMB connection has dropped
- First I thought something is wrong with the ZimaCube/OS. And it kind of is.
- My WiFi Router is set to reboot at 3 am - once the connection with the internet drops. The SMB connection gets disconnected. But there is really no need. Both computer and Zima are connected via Ethernet to the router. And the computer still has connectivity. I could even reconnect via SMB - while the internet was not connected. But then within 1-2 minutes the connection gets cut again.
This is completely unnecessary - SMB via Ethernet. And ZimaOS needing/wanting an internet connection are two separate things.
Is there a way to remove this ‘safety’. Keep the SMB connection - don’t disconnect.
- 10Gb connection
- Finally got my new switch. 10Gb + Cat 8 cables. The speed is a bit better than before when I only had 1Gb. But it’s still not great. And the widget only shows 3 rockets. Which it did before. I was expecting to see at least 4 rockets to confirm the higher connection speed.
