Feature Requests for ZimaOS
I noticed a few basic things are missing from the UI in ZimaOS that are in many boxes used for similar functions (like Free & Truenas, Synology, etc.
  1. Ability to set a Static IP in the UI
  2. ability to set DNS as well
  3. Use of NFS v3 and v4 sharing
  4. Forcing a ‘Check for update’
  5. Sending email alerts on Drive / Array status alerts
  6. (it also seems like some things are getting throttled at different times, it would be nice to have some energy vs performance settings)
Those were some of the ones at top of mind @ETWang1991
Hello, I am the product manager of ZimaOS @unix_fun
  1. IP and DNS settings will be launched in v1.3.1
  2. I have recorded NFSv3 and v4, I want to get more information, currently ZImaOS already provides Samba sharing, do you need NFS because you are used to it, or is MacOS better for NFS support, or something else?
  3. There is a Check for Updates button in the app menu, maybe the function you are talking about is already available
  4. I have recorded
  5. I have recorded
Thank you for your suggestions, we are aware of the gap with freenas, TureNAS and Synology, IW will work hard to catch up with the gap based on your suggestions. Welcome to follow our latest Beta release in our Discord.
@E-T
1&2) Glad to hear it will be in 1.3.1 (currently running 1.3.02) and will keep an eye out
  1. For NFS vs Samba, I have 0 real Windows machines in my environment and am primarily a *nix user. NFS has lower overhead and is definitely a faster protocol.
    For those reading that dont know:
    Samba: A software suite that’s primarily used for Windows systems, Samba provides file and print sharing, and integrates Unix/Linux systems with Windows networks. Samba is known for its strong security features, but it may not perform as well as NFS in some cases.
NFS: A network protocol that’s primarily used for Unix/Linux systems, NFS is designed for efficient file sharing across networks. NFS is the default file-transfer protocol in most Linux distributions. However, it’s generally considered less secure than other protocols.
3a) when it comes to file shareing and protocols, etc - it would be great to have a toggle switch to turn things off and on. (there is one protocol (that i can’t remember right now, that is very noisy on a network when it comes to fileshareing) if ii think of it ill update this) But i dont need things on the network, and broadcasting that they are here if not being used.
  1. I was really talkiing about at the ZimaOS level not the app level, it would be great to check for OS level updates (for some reason - i have never seen the red dot appear on its own, and always have to download to the …/offline directory
5 & 6) Thanks for taking note
It would be great to see a roadmap of new features shared somewhere and what releases things are planned for. (not so much for fixes, but new functionality would be fantastic)
Keep up the great work!
+1 for the NFS support. Please, consider it for an upcoming update.
+1 for me too, unfortunately I will have to go back to CasaOS until there is NFS support.
for me i would love to see:
  1. proper intergrated hardware monitoring tool that shows history (highs/lows) for cpu/network/disk temps/etc
  2. iphone/android zimaos app that backs up the mobile photo library
  3. native sync folder app for windows/linux/macos/iphone/android
  4. local control interface using the dport/hdmi to a monitor
  5. native vpn app or zimaos ID to connect remotely.
  6. Updated Zimaos app for windows. (currently the app hangs during installation)
  7. more native apps developed for zimaos specifically
Hello,
  1. Regarding monitoring tools, they have been recorded and are being studied.
  2. Before ZimaOS supports photo album backup, you can try immich in the store. We tried our best to be compatible, and found that even if we did it, it would be difficult to do better than immich (I have a 2TB mobile photo album in immich)
  3. Regarding file backup and synchronization, if possible, please tell me whether you will use the synchronization function for private files? Or a working document? @t1ll1s
  4. Regarding dport/hdmi to a monitor, it has been recorded
  5. Updated Windows and MacOS clients, including remote connection functionality
  6. We are resolving the issue where the installation process hangs
    Thank you for letting us see the direction of our efforts. I sincerely hope that you will continue to pay attention and make wishes, especially to try whether the new version of Client can be installed smoothly.
  1. The Zimaos app on my Mac works fine but the windows app is the one I cannot install. Hangs at initializing.
  2. It would be nice to have the function of a shared sync folder, like QNAP does it with qsync, even the new UGREEN has such a function. I will use it for private files. Don’t tell me that I can use nextcloud. I know, I have been using nextcloud for years in my Unraid server and honestly am not a fan. I prefer the simple native qsync on my qnap.
Hi,
I second with @t1ll1s on his request for a qsync like app… Also, an app or a built-in functionality that can automatically (either mirror or incremental) backup of data files to an external drive or a DAS. I know having a raid 1 or raid 5 is ideal but some users of ZimaOS like me use this OS on a mini pc that has limited hdd ports or nvme slots. If you, @E-T, have any suggestions let me know.
