Erro install cron.raw
Log:
starting install module…
install local raw package /media/DADOS/cron.raw
Removing invalid file: /var/lib/extensions/cron.raw, error: failed to validate raw file: exit status 1
output: Read on filesystem failed because EOF
FATAL ERROR: Can’t find a valid SQUASHFS superblock on /var/lib/extensions/cron.raw
install local raw package failed module not found
Failed to install module: module not pass validate
Looks like the .raw file is corrupted or incomplete.
Can you check:
bash
file /media/DADOS/cron.raw
It should show Squashfs filesystem. If not, try re-downloading from the GitHub Release.Also check the file size – the release cron.raw should be ~2.6 MB.If the problem persists, let me know the output of the file command!
In fact, the file I downloaded was corrupted. Now it has installed correctly. Thank you very much.
