Epic ethernet fail - be warned!
None of the ports work.
Tried 2 different cables on 4 different ports of on my motherboard.
NONE OF THE ETHERNET PORTS LIGHT UP.
What’s going IceFhail?
That’s right. You don’t get ANY ethernet connection if the backplane or a hdd cage is NOT inserted.
You can contact support@icewhale.org to help you troubleshoot
What system are you currently using?
