Effortless Joplin Installation on CasaOS with BigBearCasaOS
In this tutorial, we guide you through the seamless process of installing Joplin on CasaOS using BigBearCasaOS. Whether you’re a productivity enthusiast or a note-taking aficionado, this video provides step-by-step instructions to enhance your CasaOS experience. Join us and streamline your workflow today!
has anyone else had the issue that even after setting the correct IP instead of localhost for the app_base_url - the app still won’t launch from the zimaos docker home screen?
if i go to the http://IP:PORT address directly it works fine. and the docker app setting is set like this…
i asked bigbear to test and was told it works fine on casaos.
i already tried uninstal/reinstall (with custom install)
