Maybe I’m daft…but using a ZimaBlade… in storage manager, my drives are listed… but it only shows the model number…
Is there a way I can see the Serial Number in the web GUI?
I am using 2 drives of the same model but want to know which drive I am working with.
Thanks!!
I have noticed that as well in ZimaOS.
In ZimaOS, there is a diagram of where each drive is located on the ZimaCube based on the drive path, so they left off the serial number. I do, however, find the serial number valuable, as I generally print a label with each drive’s serial number and stick it to the front of each drive bay.
I have just started testing, so I am not sure where to file feature requests or bug reports.
