Dokuwiki vs Dashboard?
I recently installed Dokuwiki on ZimaOS 1.7.1 and followed the directions to use the http://$IP:$PORT/install.php link, fill in the requested info and saved it and clicked on the “continue to your new Dokuwiki” link. I did get to the Dokuwiki page to create your 1st page. All good.
Just a weird thing is when I click on the Dookuwiki button on the Zima Dashboard it just opens a new tab of the Zima Dashboard, not Dokuwiki. I am ok with how I have a working Dokuwiki container but was just curious about the Zima Dashboard behavior.
Should I make this a bug report?
@toolg_73349_74680 Check that the application URL is correct
Yes, that is how I got it to open from the ZimaOS Dashboard. Thanks for the tip.
During installation I was having problems with ports already being in use so I changed them but neglected to change the ip for the Dokuwiki page.
Thanks for the reply.
Please mark as solved.
