Running zimaos 1.4.4 on a zimablade 3760.
After resetting with the new feature I had to pull the Containers again (immich, paperless), now the var/lib/docker is super larger 10+GB.
should i add the nas drive for the docker directory and of yes, how to?
So, there are three suggestions I have for you:
Try to make Docker clean/prune on non used images:
Internal storage is full - #2 by victor -
Migrate your Apps and data to another location:
A guide to installing Immich to a different location - #17 by Zima-Giorgio -
You can even try to use the mounted sharing folder to your container so that you can leverage external storage instead of the internal one:
How to mount a share folder for Plex - #7 by Zima-Giorgio
Hope this is helpful. Look forward to your feedback.
The hidden folder in ZimaOS-HD/AppData/.search was grown very large +5Gb. I have removed that, also I reduced the swapfile folder to 2GB max. Now I have only 2.5GB in use for the sytem on the SSD, everything else on my RAID1 HDD. I have created a AppData/docker directory and mounted it there. Is this a funtional solution or do I have to keep the var/lib folder on the zimablade system drive?
I personally prefer to store the system, applications, and data separately. Currently, we recommend using the Migration method mentioned above to migrate the default application storage location. In the future, for users with smaller system drives, we may consider a more flexible onboarding process.
