Docker daemon crash leaves 35 of 46 running containers stopped (live-restore off by default)
After one dockerd crash, systemd restarted Docker, and the new daemon stopped all 46 running containers and flagged each hasBeenManuallyStopped=true. 11 came back on their own. The other 35 stayed off until I started them by hand.
Request: enable live-restore by default, or restart containers that were running before a daemon failure.
I suspect the crash itself is my hardware (see below). The aftermath looks like a ZimaOS default that turns any daemon failure into a major outage.
Environment
Item Detail
ZimaOS v1.8.0
Kernel 6.18.9
Docker 27.5.1 (overlay2, nvidia runtime via systemd drop-in)
CPU AMD Threadripper 1950X (32 threads)
RAM 47 GiB, plus 15 GiB swap
Containers 50 total, 46 running at the time of the crash
daemon.json Empty ({}), not modified by me
Live restore LiveRestore=false
What happened (Oct 30, local time)
Time Event
04:35:39 dockerd crashed: SIGILL: illegal instruction, exit status 2/INVALIDARGUMENT (41 min CPU, 13.3 GB peak memory)
04:35:41 systemd scheduled the restart
04:35:44 New dockerd began loading containers. For each of the 46 it logged ShouldRestart failed ... error="restart canceled" hasBeenManuallyStopped=true
04:35:54 Six containers: failed to exit within 10s of signal 15 - using the force
04:36:04 11 containers restarted automatically. Docker reported started at 04:36:05.
04:40:12 I started the remaining 35 by hand. Nothing alerted me.
Restart policies work in general: after a full reboot on Oct 29, nearly everything came back by itself.
Log line from the new daemon, one per container (container ID removed):
dockerd[2662390]: level=warning msg="ShouldRestart failed, container will not be restarted" container=<id> daemonShuttingDown=false error="restart canceled" execDuration=22h29m15s hasBeenManuallyStopped=true restartCount=0
Why most containers stayed off
Without live-restore, a daemon restart stops every container and sets the manually-stopped flag. Docker’s unless-stopped policy then skips flagged containers, while always restarts them on daemon start. That matches what I saw: 11 recovered, 35 did not. [I’ll confirm which policy each group uses and add the list below.]
Result: any dockerd crash takes down most apps, with no automatic recovery and no alert.
Request
  1. Enable "live-restore": true in the default daemon config, so containers survive a daemon crash or restart.
  2. Or add a post-start step that restarts containers that were running before the daemon went down.
  3. If edits to /etc/docker/daemon.json aren’t preserved across updates or reboots, please say where a persistent override should go.
Check if you’re affected
docker info --format '{{.LiveRestoreEnabled}}'
false means any Docker crash or restart takes down your apps.
About the crash itself
dockerd died inside runtime.memmove, called from its gRPC connection to containerd. The bytes at the faulting address are ordinary x86-64 (jb, jbe, cmp rbx,8), so this is not a missing CPU instruction.
Starting an hour earlier, unrelated programs faulted across at least six different cores. That points to unstable hardware (RAM, CPU, or power) on my side, which I’m testing. I’m not asking ZimaOS to fix the SIGILL, but pointers from anyone who has seen this on Threadripper 1000-series are welcome.
[details=“dmesg faults, 03:00-05:00 (click to expand)”]
Time Program Fault CPU
03:18:10 .NET (libcoreclr.so) general protection fault n/a
04:05:11 av1 decoder (libc.so.6) segfault 29
04:05:11 av1 decoder (libc.so.6) segfault 12
04:09:02 av1 decoder (libc.so.6) segfault 5
04:15:43 matroska demuxer (libavformat) segfault 27
04:15:43 matroska demuxer (libavformat) segfault 9
04:37:57 .NET (AMP_Linux_x86_64) invalid opcode n/a
04:40:25 .NET (libclrjit.so) segfault 7
04:41:43 h264 decoder (libnvcuvid.so) invalid opcode n/a
04:56:46 .NET (libcoreclr.so) general protection fault n/a
[/details]
[details=“dockerd crash trace (click to expand)”]
dockerd[3584]: SIGILL: illegal instruction
dockerd[3584]: PC=0x14f1a40 m=237 sigcode=2
dockerd[3584]: instruction bytes: 0xf 0x82 0xd 0x1 0x0 0x0 0xf 0x86 0x2 0x1 0x0 0x0 0x48 0x83 0xfb 0x8
goroutine 125 [running]:
runtime.memmove()  runtime/memmove_amd64.s:59
bufio.(*Reader).Read  bufio/bufio.go:258
golang.org/x/net/http2.(*Framer).ReadFrame
google.golang.org/grpc/internal/transport.(*http2Client).reader  http2_client.go:1645
[/details]
Separate issue: BTRFS errors on the 12TB drive
Counter Value
write / read / flush errors 0
corruption_errs 7438 (and rising)
generation_errs 0
The counter was already 7125 at 04:12, so the errors predate the crash by a long way. They continue at about 5 per minute, always at the same two spots (inode 273896 at offset 2441891840, inode 274304 at offset 2926067712), which something re-reads about once a minute. The data profile is single, so BTRFS has no second copy to repair from. The filesystem is 98.4% full with 1 MiB unallocated. I don’t believe this is related to the Docker issue.
  • docker-journal-excerpt.txt: crash trace, restart, and container shutdown (the full journal is 17,900 lines, mostly goroutine dumps)
  • incident-logs-full.tar.gz: full docker and containerd journals plus the kernel log for 03:00-05:00
Happy to provide more logs or run diagnostics.
docker-journal-excerpt.txt (80.7 KB)
docker-journal.txt (2.0 MB)
containerd-journal.txt (42.8 KB)
kernel-log.txt (105.6 KB)
Thank you for your feedback! I’ll forward it to the development team for investigation! I’ll let you know once there’s any news.
thank you so much and only seams to be happening on 1 of my 3 zima servers
That explains why the apps stopped, and it points harder at hardware.
What happened at 07:49:48
  • dockerd crashed with a segmentation violation (SIGSEGV, code=0x2).
  • systemd restarted it at 07:50:14.
  • With live-restore off, the new dockerd kills every container still running from the old one. That’s the “failed to exit within 10s of signal 15 - using the force” lines at 07:50:02, and it explains the exit codes 0, 143 and 137.
  • Nothing else was going on in that window. It was just the normal ZimaOS chatter, not a shutdown or an OOM kill.
Why it looks like hardware. On Oct 30 the same binary died with SIGILL, and now it died with SIGSEGV. These are two different failure types in a stock Docker 27.5.1 build, a week apart. The faulting address (0x3818cc8) is a low address, close to the crash site (pc=0x14d16b3), which in a Go binary like this is inside dockerd’s own mapped image, not a wild pointer. A bad access on a page that should be fine, plus an illegal instruction on a different day, is what flaky RAM or an unstable memory setup looks like. I can’t prove that from logs, but it now fits all of these:
  • the Oct 30 and Nov 5 dockerd crashes
  • the ext4 WARN loop in boot -3
  • the silent resets in boots -2 and -1
  • checksum errors on three disks
So the ZimaOS team has no bug to fix here. Test the hardware before you send them anything:
  1. In the BIOS, turn XMP/DOCP off and run RAM at stock speed. This is free and takes five minutes.
  2. Run memtest86+ from a USB stick for at least two full passes. Better still, run each DIMM alone if the first test fails.
If both come back clean and it still crashes, the next suspects are the PSU or the CPU.
Stop the next dockerd crash from taking everything down. Live-restore keeps containers running when dockerd dies and restarts. It won’t help if the whole box resets, but it would have prevented today’s outage. Check the current state first:
bash
cat /etc/docker/daemon.json
sudo docker info 2>/dev/null | grep -i "live restore"
If daemon.json is still empty, I can give you the exact edit. I’d rather confirm that /etc/docker survives reboots on ZimaOS before telling you to change it.
Status check. All 36 containers started cleanly. Run sudo docker ps --format '{{.Names}}\t{{.Status}}' | grep -v "Up " to see what didn’t stay up. jellyglance exited with code 1 earlier, so look at that one first.
I still need these from before, since the disk story is separate from the crash story:
bash
for i in 275936 274304 294515 273896; do sudo btrfs inspect-internal inode-resolve $i /media/12TB-Storage; done
sudo btrfs device stats /media/SSD-Storage; sudo btrfs device stats /media/HDD-Storage1
sudo journalctl -k -b -3 --no-pager | grep -v "Modules linked in" | grep -m1 -B8 -A40 -E
