I checked in VLC what the DLNA server does offer.
I was surprised that I can see the whole filesystem. Not only the media folders, but also the App folder, my own data folders, even mounted USB media.
Tested with v1.3.1-1 and v1.3.2-beta2
Is this intentional? Please reduce the DLNA access to the selected folder (/media by default).
Hello,
To facilitate ease of use, we have set the /media directory as the default initial directory for DLNA. However, users can modify this directory as needed. Please refer to the attached image for instructions on how to change the directory.
If you have any further questions or need assistance, feel free to reach out!
strong text
Thanks for your quick answer.
It was my fault: I confused /media with /media/ZimaOS-HD/Media.
I was not aware that /media seems to be some mount point for all physical drives / partitions, not the Media folder.
Now it looks good.
