Hello everyone.
The disk standby feature does not work on custom device. I have the following disks installed :
- 1 nvme 256go
- 1 HDD 500go
- 1 SSD 500go
- 2 x HDD 3to RAID5
All the disks keep spinning even if the standby is set to 10 minutes. I check the disks activity using htop (IO tab).
What is your ZimaOS version? If it is below 1.3.1, try update that and see if it is solved.
I’m using ZimaOS v1.3.1-1.
Here are my iostat values (if it can help). My RAID5 is from sda to sde. 4 of my disks are plugged directlyto the motherboard and the lasts disks plugged to a PCIE/SATA card.
avg-cpu: %user %nice %system %iowait %steal %idle
2.86 0.05 1.19 8.15 0.00 87.75
Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd
loop0 0.01 0.05 0.00 0.00 132 0 0
loop1 0.02 0.43 0.00 0.00 1127 0 0
loop10 0.02 0.05 0.00 0.00 140 0 0
loop11 0.01 0.04 0.00 0.00 110 0 0
loop12 0.01 0.06 0.00 0.00 157 0 0
loop13 0.03 0.34 0.00 0.00 892 0 0
loop2 0.01 0.04 0.00 0.00 117 0 0
loop3 0.02 0.05 0.00 0.00 140 0 0
loop4 0.02 0.15 0.00 0.00 384 0 0
loop5 0.01 0.04 0.00 0.00 110 0 0
loop6 0.09 2.97 0.00 0.00 7843 0 0
loop7 0.02 0.13 0.00 0.00 350 0 0
loop8 0.01 0.05 0.00 0.00 132 0 0
loop9 0.02 0.43 0.00 0.00 1127 0 0
md0 4.78 15.42 505.97 0.00 40689 1335208 0
nvme0n1 64.59 844.51 803.37 0.00 2228592 2120013 0
sda 4.65 61.96 164.56 0.00 163496 434270 0
sdb 4.63 62.10 164.39 0.00 163875 433798 0
sdc 4.46 61.33 164.30 0.00 161837 433582 0
sdd 4.33 61.12 163.75 0.00 161283 432134 0
sde 4.39 61.45 163.74 0.00 162161 432086 0
sdf 1.50 2.54 647.81 0.00 6701 1709524 0
sdg 11.15 111.13 0.01 0.00 293273 24 0
This is an issue that we’ve noticed, have scheduled a fix, and will address it soon.
Thank you for your response, i’ll wait for the next realeases if they fix my disks standby issues.
