Disk Monitor for ZimaOS – now available for testing
Command:
sudo hdparm -y /dev/sdb
Answer:
/dev/sdb:
issuing standby command
hdparm: HDIO_DRIVE_CMD: Invalid argument
Command:
sudo smartctl -s standby,now /dev/sdb
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.18.9] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
Answer:
Device placed in STANDBY mode
My comment:
Although smartctl reports “Device put into standby mode”, the hard drive continues to run and does not switch to standby mode.
Hello, could you please let me know if there has been any progress regarding this standby issue? Best regards, Peter
Hi Peter,
unfortunately, there is no final solution yet.
I have done quite a few tests in the meantime. The disks themselves enter standby correctly, but depending on the USB enclosure/USB bridge they can wake up again shortly afterwards. With my current setup, the behavior points strongly toward the USB enclosure/bridge being involved rather than Disk Monitor itself.
Disk Monitor only detects and displays the drive state; it does not actively wake the disks.
I am still keeping an eye on the issue and will update this thread if I find a reliable solution or if there is any relevant change in ZimaOS.
Best regards,
iSanto1306
This is brilliant. Can I add your app in my AppStore?
Hi HSinghHira,
Thank you! Of course, you have my permission to add Disk Monitor to your App Store.
In return, I’d be happy to add your App Store to my Install Monitor app.
That way, we can support each other’s projects and make them more accessible to ZimaOS users.
Thanks so much for granting permission! I’ve added your app to my AppStore
Disk Monitor on IceStore
Hello,
I’d like to follow up on the standby issue. Is there any update?
I’ve noticed that the blue LEDs on the ORICO enclosure flash briefly at regular intervals, even though I’m not accessing the hard drives. Could this be the reason the ORICO enclosure isn’t going into standby mode? Is there any way to determine the cause of the flashing blue LEDs?
I tried connecting the enclosure with the hard drives to a Windows PC. The blue LEDs don’t blink there, and the enclosure switches to standby mode correctly.
Thank you for your assistance.
Sincerely,
Peter
Hello Peter,
I think there may be a misunderstanding that I would like to clarify.
Disk Monitor is not responsible for the USB standby behavior of ZimaOS, and it cannot fix this issue.
Disk Monitor only monitors and displays information such as disk activity, SMART data, temperature, standby state and detected access. It does not control the USB controller, the ORICO enclosure, or the ZimaOS device-management services responsible for disk and USB handling.
The problem you are seeing therefore needs to be investigated and fixed at the ZimaOS operating-system level.
The regular LED activity in your video is still useful information because it may help identify which ZimaOS service is accessing or polling the enclosure. Disk Monitor can help us observe and diagnose such activity, but it cannot prevent ZimaOS itself from sending commands to the USB device.
Your Windows test is especially important: the same ORICO enclosure and hard drives enter standby correctly there. That strongly suggests that the enclosure itself is capable of standby and that the difference is caused by the host system.
So to be clear:
Disk Monitor can help diagnose the problem, but the actual fix must come from ZimaOS.
I would recommend continuing to report this behavior directly to the ZimaOS developers, including the video and the Windows comparison.
Best regards,
isanto1306
