Same problem, have 4 different disks on USB, and some of them 100% not want to sleep auto:
sdb 8:16 0 7.3T 0 disk
sdc 8:32 0 3.6T 0 disk
└─sdc1 8:33 0 3.6T 0 part
sdd 8:48 0 953.9G 0 disk
└─sdd1 8:49 0 953.9G 0 part
sde 8:64 0 1.8T 0 disk
└─sde1 8:65 0 1.8T 0 part
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.18.9] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
3.5 HDD in USB bay
sudo smartctl -i -n standby /dev/sdb
=== START OF INFORMATION SECTION ===
Model Family: Seagate Skyhawk
Device Model: ST8000VX004-2M1101
LU WWN Device Id: 5 000c50 0d5cc5b94
Firmware Version: AV01
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.5/5706
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 19 00:04:40 2026 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Power mode was: IDLE_A
3.5 HDD in USB bay
sudo smartctl -i -n standby /dev/sdc
CHECK POWER MODE: incomplete response, ATA output registers missing
CHECK POWER MODE not implemented, ignoring -n option
Model Family: Seagate IronWolf
Device Model: ST4000VN006-3CW104
LU WWN Device Id: 5 000c50 0f287fb6b
Firmware Version: SC60
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Oct 19 00:04:42 2026 EEST
m.2 SSD in USB bay
sudo smartctl -i -n standby /dev/sdd
Device is in SLEEP mode, exit(2)
2.5 external USB HDD
sudo smartctl -i -n standby /dev/sde
Device Model: WDC WD20SMZW-11JW8S1
LU WWN Device Id: 5 0014ee 609036bb9
Firmware Version: 01.01A01
User Capacity: 2,000,365,379,584 bytes [2.00 TB]
Form Factor: 2.5 inches
TRIM Command: Available, deterministic
Device is: Not in smartctl database 7.5/5706
Local Time is: Mon Oct 19 00:04:47 2026 EEST
Power mode is: ACTIVE or IDLE
Before update to 1.8.0 all disks can sleep. Fix it please asap, thanks
P.S. Opened issue on github
