Disk Bay Layout Customization No Longer Works in ZimaOS 1.8
Hi,
I’ve noticed that the “Customize your bays” feature behaves differently in ZimaOS 1.8 compared to version 1.6.
In ZimaOS 1.6, I was able to manually rearrange the disk bays using drag-and-drop to match the actual physical positions of my HDDs.
However, in ZimaOS 1.8, this functionality seems to be missing or broken. The disk bays are displayed in an incorrect order, and I can no longer drag and rearrange them.
The “Customize your bays” button is still available, but it doesn’t seem to provide the same functionality as before.
Is this an intentional change, a known bug, or has the customization method changed in version 1.8?
I’d really appreciate it if the original drag-and-drop functionality could be restored.
Thanks!
Could you please record your screen?
and whats your hardware?
Unfortunately I can’t upload videos still. I will upload screenshot, you can see there is nothing to drag and no option to move the location of HDD. I use it on two different systems both DIY. Missing the functionality on both of them.
What hardware?
System one:
CPU: Ultra 5 225
Motherboard: ASROCK B860M PRO-A
RAM: 32GB
M2 controller for SATA.
System two:
CPU/Motherboard: CWWK NAS Motherboard 8 Bay Core i5 8265U 4C/8T
RAM:32GB
Before, it was working properly after update, functionality just disappeared.
